Build Agreement Agents in Microsoft Copilot Studio Using the Docusign MCP Connector
Author Purnima Ravichandran
Purnima RavichandranPrincipal Partner Solution Architect
Summary6 min read
Learn how to use the Docusign MCP connector in Microsoft Copilot Studio to build no-code conversational agents that surface agreement insights and automate agreement workflows.
Key takeaways
• Docusign MCP connector for Microsoft Copilot Studio: Builders can use the Docusign MCP connector to create no-code conversational agents that access Docusign capabilities directly in Copilot Studio.
• Agreement workflows, now conversational: Agents can help users retrieve agreement status, surface agreement insights, generate agreements, and trigger workflows using natural language.
• Built for the Microsoft ecosystem: The connector helps bring Docusign agreement actions into tools like Microsoft 365 Copilot and Teams, so teams can work from the apps they already use.
• Secure, permission-aware access: Docusign governs agreement access at the Docusign layer, so agents can only surface insights for agreements users are already permissioned to view.
AI agents are shifting the agreement lifecycle from static, manual clicks to intelligent, conversational workflows. By using the Docusign connector in Microsoft Copilot Studio opens in a new tab, developers and low-code builders can create agents that understand agreement context, securely access repository data, and take action in real time without writing custom integration code.
This implementation uses the Model Context Protocol (MCP) to expose Docusign capabilities as tools that an LLM can reason about. Whether you are automating seller tasks or building an internal procurement bot, this pattern allows Docusign to act as a native part of the Microsoft ecosystem.
In this post, you’ll learn what’s possible today, walk through a real-world scenario, and see how to build your first Docusign agent in Copilot Studio.
What’s possible today with Docusign in Copilot Studio
What is Microsoft Copilot Studio?
Microsoft Copilot Studio opens in a new tab is an end-to-end conversational AI platform that empowers you to create agents using natural language or a graphical interface. With Copilot Studio, you can easily design, test, and publish agents for your needs. You can build a standalone agent or publish to Microsoft 365 Copilot.
What is the Docusign MCP connector?
The Docusign connector is powered by MCP (Model Context Protocol), a standard that exposes application capabilities as tools that AI agents can invoke directly. In Copilot Studio, adding the Docusign connector gives your agent access to Docusign capabilities without custom API integration.
Using the Docusign connector in Copilot Studio, your agent can:
  • Retrieve agreement status and metadata
  • Generate and route agreements for signature
  • Surface on-demand insights across one or more agreements
  • Trigger actions across the agreement lifecycle
The agent dynamically decides what action to take and when, based on user intent and the logic defined by the agent builder.
Note: The Docusign connector is currently available in the demo environment and will be generally available in production soon. You can use your existing demo account or sign up for a free demo account.
Agreement agent scenarios
Scenario 1: Agreement insights and clause extraction
Users can ask:
  • “Summarize payment terms and termination clauses from the latest MSA with Fontara”
  • "Would giving a discount of 10% to customer Zaava violate any clauses with other customers?"
  • The agent analyzes the agreement and returns key clauses, summaries of important terms, and contextual insights.
Scenario 2: Agreement status and tracking
Users can ask:
  • "What's the status of the offer letter sent to John Doe?"
  • "List agreements pending signature for more than a week"
The agent retrieves real-time agreement metadata including current status, recipient progress, and timestamps.
Scenario 3: Send agreements using natural language
Users can say:
  • “Send an NDA to Zaava using the standard template”
The agent identifies the correct template, adds recipients, and sends the agreement.
Scenario 4: Trigger end-to-end agreement workflows
Agents can orchestrate multi-step processes such as:
  • Fetching data from CRM
  • Creating agreements and routing for signature
  • Storing the signed agreement in SharePoint
The agent kicks off a workflow in Workflow Builder, passing required inputs.
Use case: Automate seller tasks with a Docusign agent
A sales team can manage agreement tasks through an agent built on Docusign in Microsoft 365 Copilot. Here's how to build it.
Let’s walk through how to build an agent for this use-case in Copilot Studio.
Step 1: Create a new agent in Copilot Studio
  1. Open Copilot Studio from your Microsoft 365 environment.
  2. From the left navigation pane, select Agents and then + New Agent.
  3. Under settings, confirm that Generative AI orchestration is enabled
  4. Enter a Name (for example, “Seller Buddy”) and a description of what the agent should do.
  5. Update Instructions to describe the agent's behavior and rules.
Note: If your Docusign account contains many similarly named templates or workflows, consider specifying the template name or ID directly in the agent's instructions to ensure consistent, predictable behavior & to add guardrails to the agent.
Step 2: Add the Docusign connector
  1. Go to Tools > Add a tool, then search for Docusign MCP and add the Docusign connector
  2. Once added, the connector appears under Tools. Click it to view available capabilities.
  3. Add any additional tools your agent needs (such as Outlook)
Step 3: Test the agent
Now that your tools are configured, it’s time to test the agent with prompts. Note: Make sure your Docusign demo account includes the required templates, sample agreements, and Workflows needed by the agent.
Open the Test pane on the right-hand side of Copilot Studio and try these prompts:
  • Check agreement status: "Check if there's an active NDA with SmartFactory Systems"
    • The agent queries Docusign's agreement repository and returns the relevant details
  • Send an agreement: "Send an NDA to Zaava using the standard NDA template"
    • The agent prompts for any missing details (such as recipient email) and sends the agreement
  • Trigger a workflow: "Trigger a Workflow to fetch customer details from the CRM and send a Data Processing Agreement to Fontara"
Use the Activity tab to verify which Docusign tools were invoked for each prompt. From here, iterate: test different prompts, select your preferred model, and refine the agent's instructions.
Step 4: Publish the agent
Use the Channels tab to deploy your agent to Microsoft 365 Copilot, Microsoft Teams, or any other supported channel.
How the Docusign connector works
The Docusign connector gives agents access to Docusign IAM capabilities, including context-aware agreement insights retrieval, natural language interaction, and real-time action. By extending Docusign into the tools where your teams already work, agents become a natural part of the agreement lifecycle without sacrificing control or compliance.
Under the hood, Docusign Iris pre-processes agreement metadata, which means:
  • Faster retrieval: Structured insights enable quick search without parsing full documents
  • Secure and compliant: Users can only access insights for agreements they're permissioned to view, with access governed at the Docusign layer
  • Efficient token usage: LLMs query pre-processed metadata rather than raw agreement text
Purnima Ravichandran is a Principal Partner Solutions Architect at Docusign, specializing in Intelligent Agreement Management (IAM) and Microsoft integrations. With deep Microsoft expertise and a passion for AI, she partners with customers and partners to deliver innovative solutions that accelerate digital transformation.
    Author Subbarao Pydikondala
