Author Mohamed Ali
Mohamed AliDistinguished Solution Architect
7 min read
Summarize with AI
    • Our example: Creating a workflow when a new file is created in SharePoint
                  Co-author: Rob Koehler
                  If you’re a power user of Microsoft tools, then you’ll want to know about Docusign’s integration with Microsoft Power Automate opens in a new tab. As we explore below, it’s easy for you to use Docusign’s core eSignature capabilities within Microsoft, saving you time and hassle when getting those important business contracts signed.
                  Already, fans of Microsoft Power Automate (previously called Flow) will know that it’s a great tool for streamlining repetitive tasks and making processes paperless. It’s why the tool is such a great fit with Docusign – we’re all about going paperless and automating key tasks, too.
                  • In procurement, a trigger could occur when a tender/project status is changed in a SharePoint list to automatically send an approved contract for execution
                  • In HR onboarding, when a new employee is added, the onboarding pack (personal profile, payroll data collection, NDA, etc) is automatically sent through an approval and signature workflow
                  Step 1: Docusign Setup
                  1. Login to Docusign Admin and make a note of your Account ID (see top left)
                  2. Create an Integration Key, a special key that enables the API-level authentication:
                    • Go to Integrations > API and Keys, and note down the “Account’s Base URI”. We will refer to this as the Base URL.
                    • then “Add App / Integration Key”, note down the Integration Key
                    • Select “Authorization Code Grant” radio button, then click “Add Secret Key”, and note down the Secret Key
                    • Click “Add URI”, and add the following: https://global.consent.azure-apim.net/redirect opens in a new tab (this may change as its generated by Power automate, but this initial value will work for now). Please note down this value of the Redirect URI for now.
                  3. Create Custom Fields
                    • Go to Signing and Sending > Document Custom Fields, click “Add Field”
                    • Choose which fields you’d like to add (e.g. signature, name, signing date) and follow the prompts. For example, if you want to add a Signature field, the recommended values are:
                      • Name: Signature
                      • Type: Sign Here
                      • Shared: Tick (yes)
                      • AutoPlace Text: \s{r}\
                  Create a Custom Connector
                  General
                  Input these details below:
                  • Host: Base URL [captured earlier]
                  • Base URL: /restapi/v2.1
                  Security
                  DEMO:
                  PROD:
                  Definition
                  Enter these values:
                  Verb: POST
                  URL: https://demo.docusign.net/restapi/v2.1/accounts/\[your opens in a new tab Account ID]/envelopes
                  Body:
                  "documents": [
                  "documentId": "1",
                  "fileExtension": "txt",
                  "name": "Doc1",
                  "order": "1"
                  "recipients": {
                  "signers": [
                  "recipientId": "1",
                  "roleName": "Signer 1",
                  "routingOrder": "1"
                  "status": "sent"
                  Test
                  Inputs:
                  • Site Address: - Sharepoint site
                  • Folder id: Folder path
                  Get file content
                  Inputs:
                  • Site Address: Sharepoint site
                  • File identifier: – This is the output from the previous step. Simply select “File identifier” under “dynamics content” on the right pane. See above screenshot.
                  Compose
                  Input
                  • Inputs: “base64(…)” – within the brackets, go to “dynamic content” and select the “Get file content” (As below). The final function should read: base64(body('Get_file_content'))
                  Add Custom connector
                  Select the Action we created.
                  Now add the following values:
                  • documentId: 1
                  • fileExtension: txt
                  • name: Doc1
                  • order: 1
                  • emailSubject: Send document for signature
                  • email: [enter signer email address]
                  • name: [enter signer name]
                  • recipientId: 1
                  • roleName: Signer 1
                  • routingOrder: 1
                  • status: sent
                  Note - For these fields:
                  Now save and run it!
                  Author Mohamed Ali
                    Author Paige Rossi
                    Paige Rossi
