How to Write a Business Plan: A Step-by-Step Guide for a Stakeholder-Ready Draft
Learn how to write a business plan step by step, from defining your audience to building a stakeholder-ready draft you can act on.
- Key takeaways
- What is a business plan, and why does it matter?
- Before you start writing, decide who the plan is for
- Start with a simple business plan outline, then write for clarity
- Review the draft like a working document, not a school assignment
- After the plan is done, prepare the documents that move the business forward
- Turn your plan into action
A business plan is usually one of the first serious documents a new business creates. A strong plan is more than a set of sections filled in one by one; it should be easy for the right people to review, question, and use to approve the next steps.
If you're figuring out how to write a business plan, you're probably looking for a guide to help you think your idea through , explain your business clearly, and structure it so you can easily get useful feedback from the people who matter, whether that's a co-founder, a lender, an advisor, or internal leadership.
That's the goal of this guide: help you build a business plan that's clear on paper and useful in the real world.
Key takeaways
A business plan should be built for a specific reader, lender, co-founder, advisor, or internal team, since each expects different levels of detail.
A standard outline (executive summary, company description, market analysis, and so on) makes a plan easier to review, but write the executive summary last.
Review is a process, not a polish step: draft, get feedback, revise, then finalize a version tailored to the intended reader.
Once a plan leads to real decisions, such as ownership or funding, the documents that follow often require formal review and signature.
A business plan is a structured document that explains what your business does, who it serves, how it will operate, and how it expects to make money. In plain terms, it helps you turn an idea into a working plan.
It matters because it gives shape to decisions that can otherwise stay vague for too long. In a 2026 Gallup survey of more than 3,500 U.S. business owners, those with a business plan were more likely to report year-over-year revenue growth opens in a new tab than those without one. Writing a plan forces you to define your customer, test your assumptions, outline your operations, and connect your strategy to numbers. It also creates a shared reference point when other people need to weigh in.
That audience matters more than many first-time founders realize. A lender may want more detail on repayment logic, financial assumptions, and use of funds. A co-founder may focus on ownership, priorities, and operating roles. An advisor may look for gaps in your market logic or execution plan. An internal team may need clarity on milestones, responsibilities, and near-term actions.
Before drafting a single section, pause and define the purpose of the document: who's reading it, and what they need it to do.
A short checklist can save you time and improve the final draft:
Identify the primary reader: Is this plan for a lender, co-founder, advisor, investor, or internal team?
Define the decision they need to make: Are they evaluating funding readiness, strategic fit, operating feasibility, or whether to move forward?
Set the scope: Decide whether this is a lean small business plan, a startup plan, or a more formal document with financial detail and appendices.
Assign ownership: Name one document owner and identify contributors for finance, operations, sales, or legal review where needed.
Choose a timeline: Set deadlines for first draft, review, revision, and final stakeholder-ready version.
This step helps you avoid a common problem: writing a generic document that tries to answer every possible question and ends up answering none of them well.
If you're wondering how to make a business plan without overcomplicating it, start with a standard structure. Most readers expect the same core sections, and that's helpful. Familiar sections make the plan easier to review.
A practical business plan outline usually includes:
Executive summary: A concise overview of the business, market, model, and goals
Company description: What the business is, who it serves, and the problem it solves
Market analysis: Target customers, demand, competitors, and positioning
Products or services: What you sell and why it matters to customers
Marketing and sales plan: How you'll attract, convert, and retain customers
Operations plan: Staffing, suppliers, tools, delivery, and day-to-day workflow
Financial plan: Startup costs, revenue assumptions, expenses, and cash flow expectations
Funding needs: If relevant, how much funding you need and how you plan to use it
Supporting appendices: Providing evidence and additional detail where needed
One tip matters here:consider writing the executive summary last, even though it appears first. It's much easier to summarize your business once the logic, numbers, and operating plan are already on the page.
As you draft each section, favor specifics over broad claims. Instead of saying you serve "everyone," define your target customer. Instead of saying growth will be "rapid," explain what actions support your forecast. Instead of listing product features, connect them to customer outcomes and business value.
This is also where a business plan template or real examples can help reduce blank-page pressure; just make sure the final document reflects your actual business, not someone else's structure copied too literally.
A business plan becomes more useful when it goes through a review process. That doesn't need to be complicated, but it should be intentional. The goal is not only to polish the writing. It's to test assumptions, catch inconsistencies, and prepare a version that others can act on.
A simple workflow often works best:
Draft: Build the first complete version, even if some sections are rough.
Comment: Share it with the right reviewers, such as a co-founder, finance lead, advisor, or operator. Name subject-matter reviewers for relevant sections.
Revise: Update weak points, resolve conflicting feedback, and tighten unsupported claims.
Finalize: Create one clean version with consistent numbers, headings, and appendix references. Record the version date, consistent financial assumptions and sources, decision status, and remaining issues.
Prepare a stakeholder-ready copy: Tailor the final version for the intended reader, whether that's a lender packet, partner discussion draft, or internal planning document.
Assigning section ownership helps here. One person might own the financial plan, another operations, and another market analysis. But one final editor should still review the full document for consistency in tone, logic, and numbers.
During review, ask practical questions:
What assumptions need more evidence?
Do the financial projections match the story in the marketing and operations sections?
What would a lender or advisor question first?
Are responsibilities, risks, and next steps clear?
If you use AI to help draft or review the plan, verify its facts, sources, calculations, and risk suggestions. AI output is not evidence that projections are achievable or that legal and regulatory requirements have been met. Use tools and information-sharing practices appropriate for confidential business data, and retain human responsibility for decisions.
If you're writing a business plan for a loan, this review stage is especially important because clarity and internal consistency can affect how credible the plan feels. If you're writing a business plan for a startup or small business, review helps make sure the plan reflects operational reality, not just ambition.
Your business plan itself may not always need a signature. But once the planning is complete, related documents often need review, approval, or formal execution depending on the situation.
For example, if your plan leads to decisions about ownership or company structure, those choices can carry legal and tax implications. It's common for follow-on documents, partnership agreements, internal approvals, financing paperwork, vendor arrangements, or service agreements to require more formal handling once a plan turns into real decisions.
A business plan shouldn't stop at writing. It should make the next step easier, whether that's alignment, approval, funding preparation, or operational follow-through.
After you finish drafting and reviewing your plan, Docusign eSignature helps you collect approvals and signatures on the related business documents that follow while allowing you to track signing status. As agreement volume grows, Docusign IAM helps manage those workflows and centralize documentation in one place.
Ready to move your business plan into action? Explore Docusign eSignature to send, sign, and track the agreements that come next.
FAQs
There's no fixed length; it depends on the audience and purpose. A lean plan for internal alignment might run a few pages, while a formal plan for a bank loan or outside investor often runs 15–30 pages and may need more detailed financials and appendices.
Yes, it's still worth writing one. Even without a lender or investor involved, a plan forces you to test assumptions and spot gaps in your thinking before you commit time and money. Academic research on business planning identifies this as one of three distinct benefits, alongside the funding and stakeholder trust that written plans build for lenders and advisors. Planning can also help coordinate decisions beyond raising capital.
Treat it as a living document rather than a one-time deliverable. Revisit it whenever something material changes, a new competitor, a pivot in strategy, a funding round, or roughly once a year, even if nothing dramatic has shifted.
This guide is offered for general information purposes only. It does not constitute, and is not a substitute for, legal advice.
- Key takeaways
